AW Direct Grommet Mount LED Warning Light, Round, 4-dia., Amber Lens
Split lenses help create unique eye-catching flash patterns. Change between 15 available flash patterns using your momentary switch. Draw .5 amp. This super bright light features clear lenses with 56 colored LEDs to provide intense light output. Rugged and durable, this light is easy to wire - simply connect power and ground wires. 12 VDC. Made in USA.
